Track and hold simulatoin
wael_wael
Full Member level 4
Dears
could some one suggest me any any paper or tutorial for simulate the sample and hold, i have designed one but i still dont know how to test it. i got nice output but still i want make sure it is works as well.
regards
seeker137
Newbie level 6
You can assemble an ideal T/H and run a sinewave through it and the actual design. Compare the ideal and actual design outputs and determine how many bits of accuracy are obtained. If you subtract the actual from ideal, you can get the non-idealities part of it (assuming they are all modelled) and then you have the actual signal to determine SNR.Hope that helps.
    wael_wael
ygu_sanjose
Newbie level 5
For distortation analysis, you can do fourier transform of the output. For AC analysis, you can just do the hold mode operation. The common mode of the input and output are defined so that you don't need to worry about the DC bypass feedback.
    wael_wael
pfd001
Advanced Member level 1
transient simulation and FFT for distortion
    wael_wael
wael_wael
Full Member level 4
thank so much, i will do that and tell you what is the result
thanx again for ur help
