track and hold circuit for 8-bit folding adc
kickbeer
Full Member level 3
Is there any recommedation whick track and hold i should use for my adc?
Input of that track and hold must be sinusoidal and has double ended output
folding adc
it depends to frequency.nevertheless i think you can use of simple switch with a capacitor (in the high speed ADCs). with fully differential topology, clock feedthrough will be removed. i think you can reach to the 48dB SNR, with this topology even in high frequency. as you know in high speed ADCs, you can't use of closed loop SH.
    kickbeer
track and hold
speed of my a/d converter would be around 70 MHz. Can your show me some example? link etc...
adc close-loop sample hold
your speed is not high, i used of mentioned SH in my project(8bit,1GSPS). besides one of the important factors for choose topology of SH is a type of your ADC. unfortunately i didn't design folded ADC yet. for example if output of SH must drive large cap(parasitic cap), you won't able to use of simple SH and you have to use of SH that contains opamp. in closed loop SH(with opamp), current of opamp will charge parasitic cap whereas hold voltage on sampling capacitor, determines voltage of SH output.
    kickbeer
track and hold adc
i don't dunderstand what u meant by this 'drive large capacitance'??
adc track&hold circuit
for example in flash ADC, 2^n comparator exists. these comparators have a large parasitic cap (it belongs to the parasitic cap of inputs of comparators), thus SH must drive large parasitic cap.
    kickbeer
track & hold circuit
the number of comparator in folding adc is much less than from flash. Mine has 40 comparators. does this considered to have large capacitances? is total input capacitances of 2pf large?
thx
ieindia.org
you should compare 2pF with value of sampling capacitor . i think it's better to test one open loop SH although it seems that you need to use of SH with opamp.besides search for some thesis or paper about folded, surely you'll find some beneficial info about this issue.
Good luck
    kickbeer
track and hold circuit example
Hello!
At 70 MHz you should respect a lot of design rules and you should be almost professional to achieve guaranteed results.
But if you have a 100 times lower frequency it will be much easier.
Everything depends on your experience and resources.
May you will find something useful below:
Sample and hold basics:
http://analog.postech.ac.kr/3.Class/1.Classes/07_695O/SH.pdf
ADCs:
Sampling and conversion:
http://www.ieindia.org/pdf/88/88ET104.pdf
http://www.ieindia.org/pdf/89/89CP109.pdf
Hope that will help you a bit.
BR
