casualStranger
Hello all
I'm having some trouble with a TPS7370 regulator. I'm using the DCQ packaging. It's being used to produce 3.3 volts for 4 different chips: a microcontroller, MAX232, M41T94 and a VCH 373 buffer. There are 2 more TPS7370's on the board which operate without any trouble. The problematic regulator works fine until it drops its voltage to 0.8. I've already replaced it twice. The chip is used on a 2 layered PCB. Sadly, there are no power planes on the PCB. To somewhat solve this problem I've used pretty wide tracks for GND and main power. Any help would be appreciated.
Thanks
Thanks
