Jun 16, 2017 #1 M musmanm Member level 2 Joined May 7, 2015 Messages 50 Helped 0 Reputation 0 Reaction score 0 Trophy points 6 Location Seoul Activity points 558 Hello! to everyone in the community. ADS simulator is giving me an error after I import the s4p file to use as a 4-port directional coupler. The s4p file is directly downloaded from the website of the Marki-Microwave company. (https://www.markimicrowave.com/Couplers/Directional_Stripline/C10-0226.aspx) I am attaching the S4p s-parameter file here. Can anyone please help me remove this error and use it in ADS tool. Thanks! View attachment C10-0226.s4p.txt
Jun 16, 2017 #2 pancho_hideboo Advanced Member level 5 Joined Oct 21, 2006 Messages 2,847 Helped 767 Reputation 1,536 Reaction score 733 Trophy points 1,393 Location Real Homeless Activity points 17,490 musmanm said: I am attaching the S4p s-parameter file here. Can anyone please help me remove this error and use it in ADS tool. Click to expand... Code: ! Port Configuration: PORT 1: Input PORT 2: Output Port 3: Coupled Port 4: Isolated Add !. Code: ! Port Configuration: PORT 1: Input ! PORT 2: Output ! Port 3: Coupled ! Port 4: Isolated
Jun 16, 2017 #3 V volker@muehlhaus Advanced Member level 6 Joined Apr 11, 2014 Messages 3,188 Helped 1,071 Reputation 2,146 Reaction score 1,138 Trophy points 1,393 Activity points 20,252 musmanm said: ADS simulator is giving me an error after I import the s4p file to use as a 4-port directional coupler. Click to expand... And what is the error message? Did you use the file with the S4P element? If yes, is that set to File Type Touchstone (not Dataset)?
