Topor topological router
difflvl
Has anyone ever seen or used this?
Schallhofer
Junior Member level 1
Itzehoe
No and I can not imagine that I could deliver such a ... solution.
kackermann
Newbie level 1
I haven't seen that particular router, but I'm writing one myself.
The secret is the use of Voronoi diagrams for path finding. It's naturally routes at any angle.
It has a scary worst case run time but a blindingly fast average case performance.
Those people are charging a fortune for it and break out the cost by layers, which is obcene. Why not just throttle it?
purplerain0724
Hi, everyone
I am using Altium Designer as my primary software suit for PCB design. But its native autorouter (called Situs) is kind of "weak". I conducted a set of experiments Situs vs TopoR and it prove that TopoR's a better solution unless you have a special requirements on solely 45 degrees routing. A 5.0 version is to be released very soon (they promised, in mid-2010).
Ultimately, Altium is a little twisting the situation claiming Situs to be a topological router. Indeed, it is, but only to a certain degree! On the other hand, TopoR embodies a topological approach to the problem. Truly, if Situs is topological, why it's angle-limited?! (For those who is not familiar with a topological approach, I can recommend Roman Bazylevich's works. He's a founder of that technique).
P.S. No, I don't work for TopoR. Please, don't regard this as an advertisement of TopoR
BTW, kackermann, how's your router doing (the one exploiting Voronoi diagrams)? Did you finish it?
