Topic on Analog IC Design
In my opinion , you should select a filed ,such as RF , Data convert , PLL.
etc, and the RF is too difficutl if you have good models and software for design ,and the testing is diffiult too.
ADC such as sigma-delta is very interesting and many sigma-delta theory and circuit theory used in it.
PLL is used widely , such as RF , Digtila system etc, and the noise performance is the key problem ,how to simulate and make it low is a good topic.
Hope this is useful for you
First read some articles/papers (simple ones from IEEE -- early years) and get a feel of what options you have. Then when you like an area ... look into more detailed papers from IEEE and decide on a topic
Do research on wireless for analog design ( LNA , PLL , Power Amplifier , Mixer , etc)it is challeging and you will learn a lot
can give some guide or refrence about analog ic design or cmos ic design, custom ic design
tnx
what is the free download link??? I couldn't download anything because i have 0 points. :(
flatulent said:
foolwu said:
I have to reply 10 times to get enough points..
time 2
You should use the free download link just below the costly points download link,
analog integrated circuit design(john-martin). Very nice book
I am also starting a research at the university on analog integrated circuit design (power amplifiers)
prof. give you freedom ,you can do what you like, but it may be too difficlty. i suggest RF ic design ,if you like
good luck
hi, hawk
where is "the art of analog design" ebook
I can not find it,:(
can you help me? thanks in advance
As a beginner, U can do some easy circuits,such as amplier, bandgap reference.U should make u be interested in this topic.It is important.
Classical circuit such as 2 stage amplifier is a good start. Especially if u have some book with step by step explaination, it would help a lot in the learning process. John & Martin book is good~!!!
u may focus on the PLL od AD/DA
there are some good and interesting topics in analog ic design.
latch up
matching
shielding
crosstalk
Here are the big topics:
Data converter,
Filter,
PLL or Oscillator
Basic topics:
AMPLIFIER(norrow band/wide band), Current/Voltage Reference
there are so many aspects .
you can refer to them and find the intersts
You can learn much about PLL or AD/DA since you have a background of digital circuit!
razavi or allen good books for you to get a feeling about analog ic design
uncle_urfi said:
For a digital IC designer, a challenging topic would be to model the inductance of the interconnects which is a pretty hot topic.
For starters,
h**p://www-mtl.mit.edu/research/icsystems/pubs/theses/thesis_pps.pdf
the above url is not opening....I also have checked with (.) in place of (-) after **broken link removed**.....
