Hello, Is there any tool that can transform python code for Machine Learning into VHDL (preferably), so that can be uploaded to a Xilinx Spartan 3E FPGA?
The vivado webpack is free. It only supports the smaller devices though.
Hello,
as @TrickyDicky said "Vivado HLS" (Webpack version) is free. You must create free account at xilinx.com and get "Webpack license" and copy it to catalog which is available from Vivado (the best is to add this catalog to PATH environment variable of Windows or Linux). This free licence allow to work with most of types of Xilinx FPGAs, for example Artix-7, Spartan-7, Zybo. These families of FPGAs should be enough for basic AI and deep learning.
Regards
mojito@ubuntu:~/Desktop/vivado/hls4ml/example-models$ hls4ml convert -c keras-config.yml
hls4ml: command not found
Ok I have installed WebPack Vivado finally. I am following these instructions....
https://fastmachinelearning.org/hls4ml/setup/QUICKSTART.html
How do I add the path on Ubuntu?
I cannot understand, I am following the instructions...!!
git clone https://github.com/hls-fpga-machine-learning/hls4ml.git
cd hls4ml/
pip install .
cd example-models/
Thank you,
Any idea why I get this error?
I mean I am following exactly the steps posted here:
which says:
ERROR: [HLS 200-70] Part 'xcku115-flvb2104-2-i' is not installed.
command 'ap_source' returned error code
while executing
"source build_prj.tcl"
("uplevel" body line 1)
invoked from within
"uplevel \#0 [list source $arg] "
hls4ml build -p my-hls-test -a
