Register Log in
TO247 FET mounted in "SMD" fashion and pressurized against heatsink with "foam"
treez
Advanced Member level 5
cambridge
We have a 4 layer PCB on which we have our offline , all surface mount, LED driver. This PCB sits on a thin thermal pad and this all lies against a big flat heatsink surface. The big flat heatsink is earthed.
Currently we use a D2PAK power FET and have thermal vias going through the PCB to bottom layer thermal copper pour…but this doesn’t give great heat conduction…therefore….
We wish instead to have a TO247 FET lying horizontally, with bent leads, so that it can be soldered as a “SMD” FET…….the TO247 tab will be screwed to a small rectanguloid of aluminium (a heatsink), which, through a small cutout in the PCB, will lie against the thermal pad, and thus give good thermal contact of the FET to the big flat heatsink.
The problem is, we cannot have a threaded hole in the heatsink, so how then will we get sufficient pressure with which to hold the rectanguloid heatsink against the big flat heatsink?….
…well, there is a flat perspex enclosure some 3mm above the top of the TO247 case (its above the whole PCB) ….and this perspex enclosure gets firmly screwed down…so yes, we are thinking we can put some kind of foam in between the TO247 case and the perspex cover, and then as the Perspex cover gets screwed down, it will pressurize the TO247 FET against the big flat heatsink……and that will do the job nicely...we hope...
But what materials can we use for the “foam pad”?
Preferably it will be non electrically conducting, and with a firm springiness so that it can really pressurize the TO247 against the big flat heatsink. Do you know of any such materials?
Kajunbee
Advanced Member level 1
Re: TO247 FET mounted in "SMD" fashion and pressurized against heatsink with "foam"
I guess you would prefer a thermally conductive foam. Not sure but it seems to me that a thermally insulating foam could be counter productive.
betwixt
Super Moderator
Staff member
Aberdyfi, West Wales, UK
I disagree with both of you! It should be thermally insulating since it is only intended to put pressure against the tab, if it was conductive, and survived the temperature itself, it would distort the perspex (acrylic) cover. I think this is a bad idea but then I have no idea what temperatures or profile your product experiences.
The hole doesn't have to be threaded, use a self-tapping screw or if the heat sink is thin enough, use a rivet. If it is close to the edge of the PCB, consider a spring clip extending over the board to do it.
Brian.
treez
cambridge
Thanks, the big flat heatsink isnt thin enough to be riveted. Unfortunately, we cannot put holes into it, in any case, they have already been manufactured without a hole in them, and its considered too expensive to put a hole in them.
Unfortunately theres no way we could easily use a spring clip.
The heat profile is that this is just an outdoor light for parking lots in Europe. We are exercising in how much power we can put through our current hardware, and so for the upper power levels, we see temperatures of nearly 130degC at the junction of the D2PAK FETs, and so we wish to change to TO247 with better thermal handling.
The D2PAK we are currently using is SPB07N60C3...
https://www.infineon.com/dgdl/SPB07...90004&fileId=db3a304412b407950112b42df065491f
fourtytwo
Member level 4
near the sea
If you stated the power dissipation, thermal resistance of your heatsink and max Ta that would be helpful as it would be possible to calculate the allowable interface thermal resistance. Is the heatsink and pcb secured to the case or are you expecting this interface to handle mechanical forces in addition to a simple thermal interface ?
Reactions: treez
    treez
treez
cambridge
Thanks, the big flat heatsink is essentially the case. The PCB is screwed to that.
The small rectanguloid heatsink is somehow to be connected to the big flat heatink
fourtytwo
Member level 4
near the sea
I assume by small rectangaloid you mean the TO247, why use convoluted language ?
So back to the real questions, do you know the thermal resistance of your main heatsink/case ?
Do you know the power dissipation of the TO247 device ?
Do you know the maximum specified Ta ?
Toggle Sidebar
