To use xilinx IP Core Generator need help!
Matrix_YL
Hi all
Can anyone tell me correct steps to use Core Generator in ISE !Actually I know how to generate IP core in Core Generator but I don't know which file shall be add in project when core generator generatre so many files (*.vhd and *.v I don't know how to use especially ).
Normally I just add *.xco to project and instantiate core it my module
Can you tell me my steps right or wrong ? or give me some advices or you common steps
Thanks in advance
Have you seen this page in the ISE Help? It works for me in ISE 8.1i Project Navigator.
I don't like Project Navigator. I usually build my projects from the command line using a makefile.
    Matrix_YL
Add e.g. l2.xco to project
Open schematic
add element l2 to schematic menu add element below item All elemements
roza
if u call the IP, the .xco file is added to ur project automatically.
to use IP core see its data sheet and in data sheet see the timin diagram related to ur application try to implement that using some logic
Working with CORE Generator IP [ISE Help]
I have used vhdl fild to add but hoe to implement this project, as i am having error map-116?
