Register Log in
to put lumped inductor between two microstrip lines in HFSS
lkminz
Member level 4
hi there
i am trying to simulate a structure having lumped inductor in HFSS. i have to put lumped inductor between two microstrip lines of certain thickness. i tried with joining them through a plate and RLC boundary over it but obtained result is not satisfactory.
i have attached the HFSS structure , required result and obtained result
any comments or suggestion would be really helpful.
james cook
Member level 4
china
build a box of vacuum across the 2 lines, define it as a inductance. The integration line should contact the 2 MS lines.
Added after 1 minutes:
The box could be just above the MS lines, and have contact with the MS lines.
lkminz
Member level 4
Re: to put lumped inductor between two microstrip lines in H
hi james thanks for replying . your statements 1)The box could be just above the MS lines
2)The integration line should contact the 2 MS lines.
are bit confussing. plz expalin the 1st statement bit more clearly .
thanks in advance
Azulykit
All over the Map.
If you have HFSS and Designer available you might want to consider co-simulating where you build the traces with HFSS and combine them in Designer with the inductor.
I would speak with one of the application engineers for the details.
Regards
lkminz
Member level 4
ya i have both software pls expalin me how to co - simulate
Added after 44 minutes:
hi james cook
i made the structure as per ur instruction .....pls check weither i have done everything correct or not ....but still result is not the required result
james cook
Member level 4
china
here is a HFSS expample.hope to clarify...
lkminz
Member level 4
thanks james
this ckt will give me more confidance in designing structure
i just want to know as u have put the vaccum box above microstrip line so why there is need to draw box a sheet would have done the work .
when i said box in between microstrip line i meant a box structure between two lines not above them any way if this the way then fine i will go along with it
if u have anything else to tell me regarding this pls do tell me
james cook
Member level 4
china
The vaccum box with lumped RLC can repsent a chip capacitor, chip inductor or chip resistor on the MS line. The box size should be of the package size.
Toggle Sidebar
