to detect clock's rising edge and falling edge
gharuda
Member level 3
Bengaluru
hello,
Iam working on memory design which requries a clock. i need to detect the Rising edge and Falling edge of the clock and to generate a corresponding pulse for for falling and rising edge. using cmos logic or nmos logic
____________________
_____ / \______
____ _____
_____/ \________________/ \________
use a delay then XOR the delayed with the undelayed.
the pulse width is the delay unit used
Why dont you use a complementary clocking scheme with D-Flops as the data capture devices. The logic can be realized using a X-OR gate to generate a pulse.
If the synchronization is not important, you can take the clock signal and then pass it through some delay and take both of them to an X-OR gate. This will give pulses at both the rising and falling edges of the clock signal.
Be careful about the component selection. I suppose that you are working on DDR circuits
    gharuda
