sreeramdravid
Newbie level 1
Hii all, iam a newbie and need to do the hardware implementation of my project.
i did all the debugging of the code on proteus and it seems to work perfectly fine . However when i wanted to check the program on actual hardware, i realised that things are not the same.
I used a TMR0 interrupt in my code. and on hardware i realised that TMR0IF flag bit was not being set(after writing small sample codes). However the simulation on proteus works just fine.
iam using the RA4 pin as an external clock source.and am using RA4 push button on PICDEM board as a clock
somebody please help me out. real urgency
