TMR0 and SERIAL both ISR not working in single program
scorrpeio
Full Member level 5
Hello,
I have written code for 89V51RD2 in C where I used both TMR0 and Serial ISR
In that after TMR0 ISR gets executed, Serial ISR stops working.
I tested Serial ISR separately by removing TMR0 ISR. In that case Serial ISR works without creating any problem.
But as soon as TMR0 ISR comes in picture, Serial stops working.
Can anyone tell me how to remove this problem?
do you disable the timer0 isr before you exit the ISR routine... its a rule to disable the interrupt flag before exiting the function????????
put the code here please......
void UART_INIT(void)
	TXD		=	1;			//TXD Pin set as I/P
	RXD		=	1;			//RXD Pin set as I/P
	SCON	=	0x50;		//mode1, 8bit UART, Reception Enable
	TMOD 	= 	0x20;		//timer 1 8-bit auto-reload
	TH1 	= 	UART_SetBaudRate(CLK_110592,
				UART_BAUD_9600);		//Baud Rate 9600 8-n-1
	TL1 	= 	TH1;						//Reload count
	ES		=	ACTIVE_HIGH_ON;	       //Enable Serial Intr
	PS		=	ACTIVE_HIGH_ON;		//Set High Priority of Serial Intr
	EA		=	ACTIVE_HIGH_ON;		//Enable Global Intr
	TR1 	= 	ACTIVE_HIGH_ON;					// Start timer
void ISR_UART(void) interrupt 4
     if	(RI)
         //copying the SBUF in the buffer and checking whether whole frame is
         // received or not
void TIMER_INIT(void)
	TMOD	|=	0X01;
	TH0		=	0XFC;	//1MSEC COUNT 65535-922
	TL0		=	0X66;
HIGHPRIORITY_TIMER0INTR	=	ACTIVE_HIGH_OFF;	//Set Timer0 interrupt as
        //low priority
	ENABL_ETIMER0INTR		=	ACTIVE_HIGH_ON;
	ENABL_GLOBALINTR		=	ACTIVE_HIGH_ON;
void ISR_TIMER0(void) interrupt 1  //using 2
	TIMER0_INTR_FLAG	=	ACTIVE_HIGH_OFF;
	START_TIMER0		=	ACTIVE_HIGH_OFF;
	TH0					=	0XFC;	//TIMER OF 1MSEC
	TL0					=	0X66;
	START_TIMER0		=	ACTIVE_HIGH_ON;
	if(u8_ColumnNo>15)
		  u8_ColumnNo		=	0;
		  Enable_74LS138	=	1;
	ROW_0_TO_7		=	0xFF;
	ROW_8_TO_15		=	0XFF;
	COLUMN_0_TO_7	=	~(1<<u8_ColumnNo);
	if(u8_ColumnNo>=8)
		COLUMN_8_TO_15	=	COLUMN_8_TO_15 + 0X10;
	ROW_0_TO_7		=	u8_DisplayBuffer[u8_ColumnNo<<1];
	ROW_8_TO_15		=	u8_DisplayBuffer[(u8_ColumnNo<<1)+1];
	u8_ColumnNo++;
