What is the difference between TLIN and MLIN?
In practical desizing we use what?
In Filter Design we can make Matching Networks via TLIN, How to convert TLIN into MLIN,if required?
TLIN is transmission line and MLIN is microstrip line.
TLIN is general:we specify TLIN with it's charectric impedance(Z0), its length(landa*K) and its beta=2*pi/landa
but for implementation in microstrip form:
for microstrip we have a substrate wirh specified h and er
we can convert the TLIN parameters to microstrip and implement in microstrip form Z0=f(W/h,er,f) we can calculate (W)
landa(eff)=landa/er(eff))
L=landaeff*K
Normally, we use microstrip line in practical........I mean the one with the inclusive of losses and everything.......but...for transmission line...i think it is more general....if i not mistaken
TLIN is ideal, so no frequency dispersive. However the MLIN do has. So when you convert the TLIN to MLIN, you'd better to do some EM simulation with MLIN.
Exact formulas are very difficult to use, as these should account for the natural behaivour such as losses and the dispersive nature of TLINES.
If you want formulas then look in Pozar chpater 3. There you can find formulas converting ideal T-LINES to M-LINES. But they do not account for losses.
Otherwise use the Transmission line calculators in ADS or MWO. These can give you the precise result. Here you supply the substrate data: loss tangent, εr etc.
Yes....i believe packaging will effect........let say you are using molding........i dont think there is any way to take packaging into account during simulation
Which line is more preferable TLIN or MLIN in the process of amplifier design of higher frequencies(34 GHZ) & why??
*the specification to be met are (S11& S22)>10dB,gain(S21>12dB) and stability factor (K>1)*
