sinns
Newbie level 2
Hi, I've recently been doing some work with the TLC5940 and I'm a little confused by the Vout rating of 17Vs in the datasheet...
If I have a bunch of LEDs in series with a Vdrop of 3.1Vs per LED at 20mAs: I supply 24Vs to the positive side of the 7 LEDs in series, I get a total Vdrop of 3.1V X 7 = 21.7V. This means I have 2.3V @ 20mA on the OUT pin, which is easily less than the 17V max.
If I set the channel to 0% duty the result is the same (2.3V at the OUT pin) presumably, since the TLC isn't perfect, there is still a small amount of current present.
I could (by this reckoning) put 300 LEDs in series with a supply voltage of 930Vs, but this screams "You are missing something!". Can I really control 930Vs of LEDs on a signal channel with the TLC in theory?
Question is, what *am* I missing here or am I not missing anything? :smile:
