LIC33
The idea is to make a small push-pull converter and to introduce exact frequency and amplitude ripple in its output in order to test some voltage ripple sensitive circuitry that I'm developing.
I have thought that TL494 might be a good choice because of its two error amplifiers that should be able to control duty cycle.
I'm aware that I could use DTC to control duty cycle indirectly. I'm also aware that I can directly provide modulation signal to the FB pin.
However, I have to use some sort of feedback from the output to achieve exact DC offset and ripple as I need.
I have read the datasheet and it seemed obvious that I could simply provide input of the error amplifier with the proper DC offset with sine wave of desired amplitude from function generator and provide simple voltage feedback from the output scaled down with the resistor divider.
Since I currently I don't have any TL494 laying around and I have to wait for the delivery I decided to first simulate the simplest circuit in Micro-Cap as a proof of concept.
However, what should have been simple became a toil because instead of variable duty cycle what I get at the output is a sort of fixed frequency, fixed duty cycle burst mode.
I became curious so I have tested the PSpice model with the first schematic (boost converter) that I found on the net and the model seems to be working correctly.
At this point I simplified the proof of concept circuit to minimum in order to at least achieve some basic duty cycle modulation but with no luck.
The circuit is currently set in push-pull configuration.
Dead time is minimal and one error amplifier is set to maximal output because according to the datasheet the amplifier demanding the minimum pulse out dominates.
It seems logical to me that providing the second error amplifier with fixed voltage and with modulated signal should produce variable duty cycle.
However, what I observe on the outputs is indeed a minimal dead time but with fixed duty cycle output bursts.
While I could perhaps use that signal to drive push-pull transformer and produce desired modulated signal at the output of the entire device I'm quite curious as to what exactly I'm overlooking. It is most likely some obvious detail but for the moment I don't see what it is.
So, could someone please take a look at the schematic and the simulation results and perhaps point the mistake?
