Tiny RTOS for AVR with SRC
artem
Turkey
scmrtos
I have seen tiny RTOS code on internet , but there was only context switch feature and nothing more .
But you can use the MuCOS and change the configuration so only necessary features will be used and accordingly less memory and resources will be spent .
nachus001
Junior Member level 2
avr tiny rtos
Hi:
go to
www.lancos.com
there is the minithreads OS that the autor claims it can run in a AT90S1200.
nachus
7rots51
avr rtos tiny
check avrfreaks freeRT0S also.
dainis
rtos mucos
FREE Tiny Preemptive RTOS For Embedded Applications
scmRTOS is a little Real-Time Operation System
intended for use with Single-Chip Microcontrollers.
scmRTOS is capable to run on small uCs with as little
amount of RAM as 512 bytes.
Written on EC++. All source code is available.
Two target platforms are supported now (corresponding ports available):
MSP430 (Texas Instruments);
AVR (Atmel)
scmRTOS may be freely distributed and used in non-commercial and
commercial projects, but its contents should be left unchanged.
artem
Turkey
rtos with avr
For information about MuCOS it is better to read Jean Labrosse book “µC/OS, The Real-Time Kernel” .
