Timing path after optimization
kenambo
Full Member level 6
India
Hi
I am having setup slack after post Route stage. I decided o manually upsize the cells..
But is it possible to upsize a particular cell and check the timing for that path alone?
and Still problem exists.. I planned to go for grouping the cells or pipelining..
how to group the cells? any command to do that?
thanks
biju4u90
Full Member level 3
In Cadence Encounter, I think report_timing -check_type setup -from ............. -to .............. command will work for your first question.
kenambo
Full Member level 6
India
Thanks it works great.
can you please explain how to group particular cells are ports together?
I mean grouping of cells or ports..?
thanks
