what are the things to consider before doing timing analysis. Wat data should be interpreted from the data sheet.
Help me through this. I haven't done timing analysis before. I wish to do it hereafter.
We cant do timing analysis in hyperlynx unless we get ddrx analyzer which is a separate package in hyperlynx. contact your filed representative to get the license.
we need to take the setup and hold time from datasheet.
Rank is based on the no of chipsets and DIMM module you are using. DIMM module can contain upto 4 ranks means 4 chipset signals.If you have 2 rank you need to select 2 i believe. I do not use hyperlynx for timing analysis. sorry i could not support more on this.
