timer/counter 1 problem in ccs pic compiler
Noman Yousaf
Full Member level 4
Lahore Pakistan
hi
i want to get 16 bit data from timer/counter1 (as event counter) to portb and c in CCS.
how can i do it?
i did it by timer 0 as counter.
by following
SETUP_TIMER_0(RTCC_EXT_H_TO_L|RTCC_8_BIT|RTCC_DIV_2);
SET_TIMER0(0);
WHILE(1)
OUTPUT_B(GET_TIMER0());
one more problem i faced, in protuse, it increases after every 2 pulses to T0CLK pin.
necati
Member level 1
turkey
18f252 t0 8 or 16bits
Noman Yousaf
Full Member level 4
Lahore Pakistan
how to check either prescaler is used or not?
i actually want to use timer 1 as 16 bits. how to split the 16 bits into 8 bits to make it out to 2 ports (may b portb and c)
pradhan.rachit
Full Member level 3
Mumbai
The TMR1 register in the PIC consists of two individual 8-bit registers to store the lower and upper nibbles.
[syntax=c]
int main(){
TRISB = 0x00;      // PORTB as output
TRISC = 0x00;      // PORTC as output
// Configure timer 1 here
while(1)
  PORTB = TMR1L;
  PORTC = TMR1H;
[/syntax]
pic.programmer
Advanced Member level 3
Try this.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
#include <16F877.h>
#use delay(clock = 20000000)
#fuses HS,NOWDT<NOLVP
unsigned int overflow = 0;
#int_TIMER1
TIMER1_isr() {
    ++overflow;
void main() {
    setup_timer_1(T1_EXTERNAL | T1_DIV_BY_1 | 0x08);
    enable_interrups(INT_TIMER1);
    enable_interrupts(global);
    while(1) {
