shubham kumar
Member level 3
- Joined
- Sep 11, 2014
- Messages
- 59
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 8
- Location
- bangalore
- Activity points
- 511
Hi
I am using PIC18F452 and MikroC as compiler.
I have a question regarding timer.
That if the timer is started using command TMR1ON_bit=1; then if I stop the timer ( TMR1ON_bit=0) and again start the timer (TMR1ON_bit=1) then the timer will start from the value it contains at the time it was stopped or it will start from the default value which was assigned to TMRH and TMRL at the time of initialization.
PS: I tried to see the values on LCD but realized later that LCD (or any) commands itself take some time, so unable to watch via programming :bang: .
