[SOLVED] Time delay circuit for delaying the output
sudarshann
Junior Member level 2
Hi Friends,
I have a simple question
input 12v -> time delay of 1 second -> output 12v
input gnd -> output gnd
I need a simple circuit that can do this. ofcourse with mcu its simple but need a simple solution with analog ic
Thank you
No Sir.
application is to drive the relay. and hence I can user darlington to drive the relay.
regarding off time even 1 seconds is acceptable
A 555 timer IC is an easy and common way to do what you are describing.
Below is a method which is more or less equivalent.
When the input goes high, the capacitor begins to charge. After a second it reaches about 1.4 V. The darlington array turns on, energizing the relay coil.
When the input goes low, the capacitor takes a second or two to discharge, resetting it for next time.
