It wont hurt to tie them high to avoid some noise.
Also, if you have spare registers you may connect them to the clock which should create a clock tree, so if you use the register it will have the right insertion delay
You can not leave an input pin floating. You have to tie it to hi or low or a known
signal such as clock. Otherwise short circuit current through PMOS & NMOS could happen and waste power consumption.
