Re: explen
hello please how can connect tca785with pic16f877
If you want to use TCA785, you don't need mcu, you can make everything with hardware.
Look examples in datasheet.
Pin1 = V-
Pin5 = sinhronisation with AC voltage you want to regulate
Pin6 = inhibit, put it to V+ via 10k
Pin9 = 22k +trimer 100kOhm (pin9 & pin10 are used to make triangle voltage, when you change resistor on pin9, you change amplitude of triange voltage)
Pin10 = 47nF
pin11 = regulating voltage 0-10VDC, 0VDC max output voltage (thyristors work as much as they can), 10VDC min or zero output voltage
pin12 = 1n (with this pin you define how long will be your impuls to thyristor gate) If pin 12 is connected to ground, pulses with a duration between trigger point and 180° will result.
pin13 = V+
pin14&15 = trigger pins for thyristors
pin16 = V+
There are several examples in datasheet, so you can see some applications. You can find some applications using google.
If you really want to use PIC mcu, than PWM out can be used to generate control voltage (pin11), but in that case you have to trim trimer 100k to have triangle voltage with 5 volts amplitude (because triangle voltage and control voltage are compared inside chip....).
I use TCA785 a lot, I made several 3 phase regulators with this chip and must say it's working very nice.
Mr.Cube
