Note:
If more than one DCMatch analysis is specified per simulation, only the last
statement is used.
Example 1
In this example, HSPICE reports DCMatch variations on the voltage of node 9,
the voltage difference between nodes 4 and 2, and on the current through the
source VCC.
.DCMatch V(9) V(4,2) I(VCC)
Example 2
In this example, the variable XVal is being swept in the DC command from 1k
to 9k in increments of 1k. DCMatch variations are calculated for the voltage on
node out. Tables with DCMatch results are generated for the set XVal={1K, 4K,
7K, 9K}.
.DC XVal Start=1K Stop=9K Step=1K
.DCMatch V(out) Interval=3
