Threshold Voltage for NMOS and PMOS transistor
sykab
Member level 2
I want to know if a nmos or pmos transistor are in the saturation region. So vds>vgs-VT. My problem is that I don't know the exact value of VT for nmos and pmos.
I'm using AMS technology 0,35 µm.
Thanks
Threshold Voltage
you can just do a dc simulation saving the OP
check the vdsat of the transistor, if Vds is larger, then you are safe in saturation ;-)
    sykab
Re: Threshold Voltage
Ok, but I need this information to dimension the transistor, this is, before I do any simulation.
Thanks
Vt depends on a lot of factors. In submicron regime, it starts depending on W and L too. So I suggest for the first cut, you can run a simple OP simulation of an nMOS and a pMOS transistor. The OP analysis (atleast in CADENCE) allows you to see the complete operating point analysis of the transistor including all the device capacitances, gm, gds, gmb, vt, ...
You can assume the Vt that you get as the threshold voltage of your transistor and calculate the dimensions required for your particular application. The saturation voltage Vdsat is almost always less that Vgs-Vt. So once you set Vds>Vgs-Vt, Vds would automatically be greater than Vdsat.
    sykab
Threshold Voltage
As spminn says, Vth is a technology dependent factor. You either must have the kit from AMS and run sims or have numerical data such as Idsat that allows you to extract the quadratic expression coefficients
    sykab
Threshold Voltage
Do DC Operation Point Analysis (suboption in DC analysis options window) then ADE/Results/Print/DC Operation Point and select device. In arised window you are able to see some MOST internal parameters.
The explanation of all parameters you can find by typing "spectre -h bsim3v3" in terminal.
The most interesting of them are: gm, vth, vdsat, ids, gmoverid, region.
Also you can annotate some of them on schematic by ADE/Results/Annotate/DC Operation Point + DC node voltages. Diplayed information depends from design kit.
It's better check that vds>vdsat instead vds>vgs-vth. Because vds>vdsat is valid for all inversion level and vds>vgs-vth only for strong inversion.
P.S. I may make a mistake in names, but I'm sure you will find.
    sykab
    V
Threshold Voltage
The CDS can show all of the parameters around the target transistor in the schematic. You can fool around with the "component display" option.
For 0.35um, the Vds>Vgs-Vth only can give you the ballpark about how the transistor behaves itself. Don't stick to linear/saturation too much. Just look at the gm/ft/current density.
    sykab
Threshold Voltage
You got to find it by testing the mos by using it in a simple circuit! But it will be usually in the range of .5 or .6 mV generally! But it varies because of many other paramaters.. So better test your MOS and find out the precise value!
    sykab
Thanks
Do you know how to connect a nmos or pmos to a diode?
after you do that, make it's current Id equal to 1uA, then the Vgs=Vds will close to threshold voltage.
it is my method to understand the Vth.
    sykab
Thanks
Yes, I know how to connect a Mos to a diode!
Thanks a lot :).
Threshold Voltage
Hi ,
U can run operating point simulation and see .chi file in run directory for all relevant values of transistor.
Even if u have wrongly put the w/l values u will get the Vth values in the .chi file.
Hope this helps
Supreet
    sykab
sykab said:
Thanks
Thanks a lot :).
Welcome.
I usually set 1uA as the Id, but it will be set as 10 uA for large W/L.
The Vth is the voltage that the MOS can be turned on. So the most important thing is how to define 'turned on'.
Good luck.
    sykab
