kathmandu
Full Member level 5
Hello,
I need to connect some electret microphons to a CCTV system and I only have (already in place) some one pair STP cables.
The microphones came with a low-noise preamps thus the output is around 1V p-p signal.
I've tried to connect one of the pair's wire to Vcc (12V), the other one to mic output and the ground (shield) to power supply ground but I got a lot of noise. I have a power supply stabilizer and filter on the mic side hence the mic should have quite a clean 5V supply voltage.
I suspect the ground wire (20m long) to be the main culprit, as the parasitic voltage across it is actually summed up with the mic output.
Is there any solution to avoid this? Do I need to run a separate ground wire for the mic output? What about the ground loop, in this particular case?
Thanks in advance for any suggestion.
