thomson dsf 8911 satellite tuner module pinout ?
Kripton2035
Western Europe
dsf8911
hello,
I just grab some tuner of these..
does anybody have the pinout of it ??? didnt found anything worth in google !
or any other tuner module containing the circuits:
stv0299b
tda8060
tsa5059
regards,
sat tuners pinout
this arch is used in many dvb tuner, like alps BEBS1-70Xa, PHILIPS 1278/SH/LH,
here are for your the datasheeet for alps bebs1-70xa.
good luck .
dsf satelite
thanks.
here is a picture of the thomson tuner i have
there must be the same pinouts than in your alps tuner but may be not at the same place. will have to search a little !
Salut Hello
voici une utilisation du tuner Thomson....
You can see an aplication of Thomson Tuner ....
pluton75P
Bonjour,
merci bcp pour ce lien. il explique bcp de choses, malheureusement après exploration des pages je n'y trouve pas le descriptif des broches du tuner...
auriez vous un datasheet sous la main? merci encore .
