This LED SWR meter any good?
doug08
Junior Member level 3
Florida
I am only looking for a simple circuit that will let me know if my antenna is matched fairly close. NOT looking for total perfection. Any idea what the proper way to use/adjust it is?
Thanks.
The circuit it will not work as a SWR meter, because there is no directivity in the coupler used.
You need a transformer or coupled lines to do the job.
Here is an example:
Thanks for the reply. It just goes to show that people place bad /non-working schematics on the internet.....why they would waste their time I will never understand. I have everything for the schematic you told me to look at. The 10pf trimmer is used for fine tuning? Anything else you can tell me about this circuit before I build it? Usage/design etc....
Thanks
Thanks
before you start building, you should really tell us what freq you are interested in using the meter on
Looks like a bridge circuit to me, which could be used to measure the load impedance.
Bridge circuit - Wikipedia, the free encyclopedia
yup exactly and you wont measure SWR with a bridge ! :)
OP have a look here for a real SWR meter :)
Dave
Reactions: doug08
    doug08
That link was perfect. Very informative. Thanks.
Not during regular operation, of course. You would use a coupler for that.
But as a "measurement instrument", bridge is fine (and broad band) to measure antenna input impedance.
"But as a "measurement instrument", bridge is fine (and broad band) to measure antenna input impedance. "
So If I was to make that bridge, I would connect it to my transmitter and antenna and it would let me know if the antenna is a good match for the transmitter by the LED not lighting up?
The configuration is not a bridge. Is just a simple diode detector followed by an LED which will indicate just the peak forward power.
You can see here a simple impedance bridge.
:roll:
Red = one arm of the bridge
Blue = other arm of the bridge, consisting of 51 ohm and antenna
Diode is between the arms, and will see RF power if the bridge is out of balance (i.e. antenna <> 51 ohm)
Rectified signal will then light the LED
