Dear All
Please see picture
This is my Proteus project connected to 16f877a MCU with keypad. when I press the key the result put to the portc
please advice, is this cct is correct?. meanwhile please send me a sample ASM code for this cct to understand the operation of keypad.
Thanks
Dear All
Please see picture
Thanks
View attachment 70831Dear All
Please see picture
Thanks
As far as hardware connections go, there isn't much to say. Since, it all really depends on the code. The keypad connection is correct, but the code must use the connection as shown. You should use resistors for the LEDs, between the port pins and the LED anodes. For simulation, you should use "active" LEDs, not just "device" ones. Go to the window, where you select parts (p on keyboard). Type in LED. 2 places below the default selected part are the "active" LEDs for simulation.
