silvio
Advanced Member level 3
at89s52 isp
For the peoples involved in programming of Atmel microcontroller AT89S51,
AT89S52, AT89S53, AT89S8252, AT89S8253 using the Atmel ISP program:
http://www.atmel.com/dyn/resources/prod_documents/At89isp.zip
This is the cable described in this doc:
http://www.atmel.com/dyn/resources/prod_documents/doc3310.pdf
As a reminder this is the program that helps you to program the above mentioned microcontrollers through ISP interface, without removing from the target board.
Just use the adapter cable fitted between PC parallel port and the target board.
Instead 74LS125 you must use 74HCT125.
