Re: ns2 installation
nstallation &validation failed in ns2.31 on ubuntu 10.04 lucid
hi sir
Actually me and my friends trying to install ns2.31 on ubuntu 10.04 since 1 month but not good results came yet.this is the error came when i install and validate....
error occur while ./install
checking for XShmAttach in -lXext... yes
checking for ranlib... ranlib
checking for a BSD-compatible install... /usr/bin/install -c
checking system version (for dynamic loading)... Linux-2.6.32-33-generic
No explicit static compilation flag; setting V_STATIC to ""
checking for dlopen in -ldl... yes
configure: creating ./config.status
config.status: creating Makefile
rm -f libotcl.so otcl.o so_locations
gcc-4.3 -c -g -O2 -DNDEBUG -DUSE_SHM -fpic -I. -I/home/guna/ns-allinone-2.31/include -I/home/guna/ns-allinone-2.31/include -I/home/guna/ns-allinone-2.31/include -I/include otcl.c
make: gcc-4.3: Command not found
make: *** [libotcl.so] Error 127
otcl-1.13 make failed! Exiting ...
See
The Network Simulator ns-2: Installation Problems and Help for problems
guna@ubuntu:~/ns-allinone-2.31$
error occur while ./validate
Running test full-asymmetric:
../../ns test-suite-delaybox.tcl full-asymmetric QUIET
./test-all-template1: 149: ../../ns: Too many levels of symbolic links
Test not implemented
All test output agrees with reference output.
Fri Dec 30 12:22:30 IST 2011
These messages are NOT errors and can be ignored:
warning: using backward compatibility mode
This test is not implemented in backward compatibility mode
validate overall report: some tests failed:
./test-all-simultaneous
to re-run a specific test, cd tcl/test; ./test-all-TEST-NAME
Notice that some tests in webcache will fail on freebsd when -O is turned on.
This is due to some event reordering, which will disappear when -g is turned on.
guna@ubuntu:~/ns-allinone-2.31/ns-2.31$ source ~/.bashrc
guna@ubuntu:~/ns-allinone-2.31/ns-2.31$ ns
ns: command not found
sir,
i used so many different installation steps all is failed, currently i used this steps......
How to install NS2 with Ubuntu 10.04 By Noor Zaman
This manual will work for NS2 allinone-2.34 with Ubuntu 10.4. As Ubuntus new version 10.04 needs following packages before any further installation, otherwise it will not work with it.
Please follow the following steps:
1. Install necessary tools for building:
sudo apt-get install build-essential autoconf automake libxmu-dev gcc-4.3
2. It turns out that otcl does not like the version of gcc installed by default in Lucid. So go ahead and change ns-allinone-2.34/otcl-1.13/Makefile.in. Find the line that says:
CC= @CC@
and change it to:
CC= gcc-4.3
3. Now follow the following steps for installation of nsallinone 2.34 and it will work with your machine. (copy ns-allinone-2.34.tar.gz)
Suppose that there is "ns-allinone-2.33.tar.gz" in current directory (e.g. "~/" for me is "/home/noor").
All steps are done in Terminal, so open a terminal in Accessories/Terminal.To extract the file:
tar xvfz ./ns-allinone-2.33.tar.gz
4. Change your directory within terminal as following way
$ cd /home/noor$ cd /home/noor/ns-allinone-2.34
5. Download & install some packages from repository if needed (Now its optional)
$ sudo apt-get install build-essential autoconf automake libxmu-dev
6. Install the ns2
$ cd ns-allinone-2.34
$ ./install
7. Edit some paths
$ gedit ~/.bashrc
8. Put these lines on that file in the last. Off course, you might change /home/noor for it depends on where you extract ns-allinone-2.34.tar.
# LD_LIBRARY_PATHOTCL_LIB=/home/noor/ns-allinone-2.34/otcl-1.13NS2_LIB=/home/noor/ns-allinone-2.34/libX11_LIB=/usr/X11R6/libUSR_LOCAL_LIB=/usr/local/libexport LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$OTCL_LIB:$NS2_LIB:$X11_LIB:$USR_LOCAL_LIB# TCL_LIBRARYTCL_LIB=/home/noor/ns-allinone-2.34/tcl8.4.18/libraryUSR_LIB=/usr/libexport TCL_LIBRARY=$TCL_LIB:$USR_LIB# PATHXGRAPH=/home/noor/ns-allinone-2.34/bin:/home/noor/ns-allinone-2.34/tcl8.4.18/unix:/home/noor/ns-allinone-2.34/tk8.4.18/unix:/home/noor/ns-allinone-2.34/xgraph-12.1/NS=/home/noor/ns-allinone-2.34/ns-2.34/NAM=/home/noor/ns-allinone-2.34/nam-1.13/export PATH=$PATH:$XGRAPH:$NS:$NAM
9. Validate it (take very long time compare to install process)
$ cd ns-2.33$ ./validate
10. Let it take effect immediately
$ source ~/.bashrc
11. Try to run it as following way, by just typing ns with terminal
$ ns
12. If the installation is successful, then you will be able to see % at the command prompt. Type following command to exit
% exit
13. Good luck and please keep remember me in your prays(Thanks in advance). Noor Zaman, King Faisal University, Saudi Arabia.
sir pls help me...thanks in advance.....
