Candy8866
Member level 2
splitting rtd signals
Detailed info:
DIN3 series low cost, small size passive isolation amplifier.
(1) 0 ~ ± 10V / 0 ~ ± 20mA DC signal isolation converters, low-cost, small size, can be welded directly into the equipment PCB board, no external components needed, no zero and gain calibration need, very easy to use. Power / signal input / output 3-port 3000VDC isolation. Industrial temperature range: -45 ~ +85 ℃.
http://www.szsunyuan.com/sy/upload/ISOEM_U(A)_P_O.pdf
(2) ISO EM series DC (voltage / current) signal isolation amplifier IC can weldin PCB board directly, no zero and gain adjustment need. The device enable 0-5V/0-10V/0-75mV/0-2.5V/0- 1mA/0-10mA/0-20mA/4-20mA signal conversion with isolation. Precision grade: 0.1, 0.2, full scale nonlinearity <0.1%.
(3) SY Series low-cost, small size DC signal converters is SIP 8Pin UL94-V0 flame retardant package, no external external components needed, no zero and gain calibration need. Signal input/output are not isolated, Power/signal isolation up to 1000VAC.
http://www.szsunyuan.com/sy/upload/SY_U(A)_P_O.pdf
(4) 8-channel (0)4-20mA programmable signal acquisition, all channels isolated to each other, accuracy better than 0.05%, RS-485/232 output. Program control accuracy calibration. High reliability, easy programming, easy to install and wiring. User can set module address, baud rate etc by program.Support Modbus RTU protocol
(5) EMC interference resistance analog signal isolation amplifier. the IC integrates interference suppression filter circuit at input, and interference absorption circuit at output. The series has strong anti-EMC and high-frequency interference, particularly applicable to the scene, where frequency control devices, high-power electromagnetic starter, GPS devices, etc are used.
(6) Two-wire (0)4-20mA loop isolation IC, can be directly welded on PCB board. Very small input equivalent resistance enable ultra-wide input voltage range (7.5-32V), which meet the needs of precise long-distance transmission without an external power supply.
(7) ISO series thermal resistance isolated transmitter IC. 2/3/4 wire Pt100 RTD signal input, output 0-5V/4-20mA etc. Built-in linear processing and compensation circuit, Power / signal input / output 3-port 3000VDC isolation.
(8) Frequenc signal isolation transmitter can be converted to analog signals unit pulse signal. International standard signal input :0-5V / 0-10V/1-5V/0-10mA/0-20mA/4-20mA and so on. Standard signal output :0-5KHz / 0-10KHz/1-5KHz and so on. Power / signal input / output 3-port 3000VDC isolation.
http://www.szsunyuan.com/sy/upload/ISO_U(A)_P_F.pdf
(9)isolation amplifier with power distributing for two-wire sensor (passive type) IC, low-cost, small size, SIP 12Pin package. No external other components needed, no free zero and gain adjustment need. Mainly used in the field where the sensors needs power supply control. 5V/12V/24VDC, etc. Enable 0-75mV/0-2.5V/0-5V with 4-20mA signal isolation, amplification and conversion.
(10) four-channel Analog Input data acquisition module, RS485/232 output isolation. 0-5V or 4-20mA input option. High reliability, easy programming, easy to install and wiring. User-programmable settings module address, baud rate and so on.
(11) True RMS (RMS) signal isolation amplifier. RMS module is based on a TRMS / DC converter, use new D-S calculation method, integrate a high-precision signal isolation amplifier. The module provide accurate, real-time measurement of the RMS signal waveform, no need to consider the parameters and waveform distortion.
(12) two-wire 4-20mA passive sensor signal loop-type isolation power distribution IC, enable power distribution of 16V-21.5V to 2-wire passive sensors. The chip can be used for signal measurement, long distance transmission and isolation. The IC is designed for applications where 24VDC and sampling resistor (load resistor) are connected in series, with Explosion-proof function. Conformed to usual input interface board (PC), PLC, DCS or other analog instrumentation input port. ISO 4-20mA-F products is easy to use, no external power supply, no calibration needed.
(13) two-wire 4-20mA isolated conditioner IC, is designed for applications where 24VDC power supply and sampling resistor (load resistor) are connected in series, loop powered system (explosion-proof) . Output conform to input interface board (PC machine), PLC, DCS etc. ISO 4-20mA-P is very convenient to use, need simply add a 50KΩ potentiometer for calibration ADJ.
(14) ISO series DC signal photoelectric isolation amplifier IC, isolate input signals, converte them into a proportional DC output. The series use the DC-signal analog modulation technique, rather than signal carrier technology used in ISO EM series. Optical isolation amplifier has a stronger anti EMC and high frequency interference character than magnetic isolated amplifier.
(15) high current output(0-500mA/0-2A) signal isolation amplifier, contains high-precision amplifier and power amplifier circuit. The device is mainly used where current signal or voltage signal's drive capability is relatively high. It can also be used to drive solenoid valve, electromagnetic switches or high-power load etc. The series is in DIN rail enclosure.
(16) Pt100 RTD isolation transmitter/splitter, is standard DIN 35 rail enclosure. 2/3/4 wires Pt100 RTD signal input directly. Easily split a temperature signal input into 2, or 4 outputs.
(17) ISOEM 1001 Series AC signal (DC bi-directional signal) isolation amplifier, the biggest features of the device are: When input is bi-directional DC-signal, and output voltage signals, zero and span can be high-precision adjusted accordingly. When the output is current signal, please refer to the ISOEM U - P - O or ISOEM A-P - O Series products instead.
(18) 0-10mV/0-20mV/0-75mV/0-100mV small signal isolation amplifier/converters. The isolated power supply of the chip can not only power the internal amplifier, but also give input ports a group of isolated DC power supply and a reference voltage source, which can be used for the expansion of the external circuitry, such as bridge circuits and benchmark circuit. SMD structure technology and new isolation technologies enable the device to achieve Power / signal input / output 3-port 3000VDC isolation, and meet the industrial wide temperature, humidity, vibration, poor working environment need.
(19) ISO 4011 multi-range high-precision analog data acquisition modules, realizes sensor to host signal acquisition, or analog signal detection, or control of remote equipment. Through software configuration, can be used with a variety of sensor types, including analog input/analog output, and digital input / output (I / O). Products can be used in RS-232/485 bus based industrial automation control systems, temperature measurement, monitoring and control, small-signal measurement, and signal transmission.
(20) ISO series frequency Signal Isolation converters, realize sine wave, square wave, sawtooth wave, etc signal isolation amplification and conversion. The device convert 0-1KHz/0-5KHz/0-10KHz frequency signals to 0-2.5V/0-5V/0-10V standard voltage signal or 0-10mA/0-20mA/4-20mA current signal . Both DIP 24Pin PCB and DIN 35 enclosure available.
(21) linear electronic scale, displacement, potentiometer, angle sensor, dedicated isolation transmitter. The device uses input filtering, protection circuits, high-precision baseline IC power regulator circuit, amplification circuit, zero and span ADJ etc transformation circuit. Widely used for amplification, conversion, isolation and transmission.
(22) low-cost, small size (SIP 8Pin) UL94-V0 flame retardant package, DC signal isolation amplifier, no external potentiometers and other components needed, no need for zero and span adj.
Detailed info:
