Hi
I am new in ic design and i want to know the principle on
how to implement the shermal shutdow in a ic. can someone
show me a link or book which relate in detail for this subject?
It is usually implemented by comparing a PTAT voltage with the bandgap voltage, or a PTAT voltage with a Vbe, you can set your trigger point by adjusting the voltages.
the principle goes like this..
a fixed reference base voltage (lower than Vbe) is applied in an off-state NPN transistor (biased by the resistor).
when temp rises, transistor Vbe goes down, thereby, triggering the transistor when it reached a Vbe lower than the reference voltage..
when the transistor conducts, it shorts VCC to the ground, hence, shutting down the ckt...
i am sorry, i also do not have material of this...
