thermal flasher bulb is not periodic??
FMradio
Member level 3
Heaven
thermal flasher bulb??
i have a thermal flasher bulb but its flashing sequence is not periodic , why?
Re: thermal flasher bulb??
Possibly it's sending a hidden code? :D
Thermal flasher Bulb flashing depends on the room Temperature + air flow + the variation of applied voltage,
i think may be the thermal flasher bulbs r not designed to give accurate periods ,
use some electronic flasher with ordinary Bulb
    FMradio
