Thermal Analysis on PCB board
gmittal
Junior Member level 1
pcb thermal analysis
Hi all,
I want to perform thermal analysis on the PCB board I am working on, so I can find which part of PCB gets more heated as compared to the other parts.
I know Mentor has a tool hyper lynx to do this type of analysis. I was wondering if cadence has something similar to it that can perform thermal analysis on the PCB board.
In order to perform thermal analysis what type of information or data is required
Thanks
Gaurav Mittal
nschutten
Member level 4
thermal analysis pcb
I am not familiar with the commercial tools (I think they are too expensive), but I have some success with ThSim (from sourceforge.net). This program translates the heat generation/distribution network to an electrical RC equivalent and then uses Spice for simulating this, then reads back this data and displays the heat dissipation in the structure.
The basic inputs that you need are: material properties (size, thickness, thermal conductivity, specific heat capacitance, specific weight) and the generated power.
abhi002
Full Member level 5
searching
thermal analysis of pcb
Hyperlynx is not for thermal analysis..
it is used for signal integrity and EMC analysis..
for thermal Mentor is having BETASOFT tool..actually this tool was acquired by Mentor last year if i am not wrong.
you have to check with CADENCE whether they are dealing with that tool?
Regards,
abhi
juripero
Member level 4
pcb thermal analysis tools
The two most used thermal analysis tools:
FlowTherm from MentorMentor
Icepak from Ansys
IRECAD
Newbie level 6
what is pcb thermal analysis
I use Orcad & to carry out a thermal analysis I use IDF out > Solidworks > into CFDesign.
