Kepsz
Member level 1
My input is a 12bit value form a DAC output. (0..4095 in decimal) I'm using 4 seven segment display, where i willing to see voltage in this form: x.yyy where X is the integer part, yyy is the fraction. In Xilinx ISE, there is problems with fixed / floating points package, so i had to work with integer values only. (see my project in youtube for easyer understanding: Digilent Basys2 starter kit - 0 to 3.3V digital voltage meter with multiplexed BCD display - YouTube )
My solution:
Because of 0..4095 = 0..3,3V, output = input * 3300 / 4096, thats written in the code below. For Example 2097 from input results 1689 in the output, wich means 1.689V in display.
This code works in my starter kit, but ISE gaves some erro:
The problem is with the temp0 := temp0 * "11001110001"; line. For example multiplication of 111111111111 (4095) with 11001110001 (3300) gaves the value of 11001110000100110001111 (6752655) in temp0 from 22 downto 0. If i dont put this & "000000000000" after "000000000000" & INPUT1, right half of the 11001110000100110001111 bits goes to trash. If i write only this: temp0(23 downto 0) := unsigned(INPUT1 & "000000000000" );, it works in simulator, but not in my starter kit.
I tryd using to instead of downto in math, it's also worked well in simulator, giving correct values, but also dont worked in my starter kit.
So if there is a more better solution, please help me.
My solution:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
entity math is
port (
CLK_in: in std_logic;
INPUT1: in std_logic_vector( 11 downto 0 );
OUTPUT: out std_logic_vector ( 11 downto 0 ));
end math;
architecture Behavioral of math is
begin
Process(CLK_in, INPUT1)
variable temp0: unsigned (35 downto 0);
begin
if (rising_edge(CLK_in)) then
temp0(35 downto 0) := unsigned("000000000000" & INPUT1 & "000000000000" );
temp0 := temp0 * "11001110001"; -- * 3300 (1000 * 3,3V)
temp0 := temp0 / "1000000000000"; -- /4096 (power of 2)
OUTPUT(11 downto 0) <= std_logic_vector(temp0(11 downto 0));
end if;
end process;
end Behavioral;
Width mismatch. <temp0> has a width of 36 bits but assigned expression is 47-bit wide.
