if in any system design, a slave has a memory value of suppose 32bits(for example) and there is a transfer data of 64 bit suppose, then the master uses a wrapping burst inorder not to cross the 32 bit bounday,
i.e if it starts with 8 bit beat transfer 0,8, 16, 24, here it wraps to the earlier stage as there is no more memory left higher than 31 bits.
