1n5806 spice
* MEASURED TRR = 36.8NS, SIMULATED TRR = 27.00NS.
* TEMP: 125
.MODEL D1N5806/125C D (
+ IS = 1.82094E-8
+ RS = 0.1187774
+ N = 1.6444874
+ TT = 2.96E-8
+ CJO = 3.15091E-11
+ VJ = 0.4
+ M = 0.2078398
+ EG = 1.11
+ XTI = 3
+ KF = 0
+ AF = 1
+ FC = 0.9
+ BV = 1E5
+ IBV = 1E-10
* GENERIC FUNCTIONAL EQUIVALENT = 1N5806
* MANUFACTURER = MICROSEMI
* TYPE: DIODE
* SUBTYPE: RECTIFIER_FAST_RECOV
* THIS FILE CONTAINS 3 PARAMETER SETS FOR NON-IRRADIATED DEVICES AT
* VARYING TEMPERATURES OF THE 1N5806.
* PARAMETER MODELS EXTRACTED FROM MEASURED DATA.
*** CAUTION: USE ONLY AT TEMPERATURE SPECIFIED. ANY DEVIATION FROM THIS
* TEMPERATURE WILL PRODUCE INCORRECT RESULTS.
*** CAUTION: THE MEASURED TRR AND THE PSPICE CIRCUIT SIMULATED TRR ARE
* DIFFERENT.
* THIS COULD POTENTIALLY LEAD TO ERRORS IN CIRCUIT SIMULATIONS
* IF USED AS A RECTIFIER OR SWITCHING DIODE.
* BV, IBV, XTI, EG HAVE NOT BEEN EXTRACTED AND ARE SET TO DEFAULT VALUES.
* MEASURED TRR = 26.08NS, SIMULATED TRR = 15.09NS.
* RAD: PRERAD
* TEMP: 27
.MODEL D1N5806/27C D (
+ IS = 1.82777E-8
+ RS = 0.1367235
+ N = 1.6126814
+ TT = 1.343E-8
+ CJO = 3.21228E-11
+ VJ = 0.3
+ M = 0.2
+ EG = 1.11
+ XTI = 3
+ KF = 0
+ AF = 1
+ FC = 0.5
+ BV = 1E5
+ IBV = 1E-10
* MANUFACTURERS PART NO. = 1N5806
* TYPE: DIODE
* THIS FILE CONTAINS 3 PARAMETER SETS AT VARIOUS POST NUETRON RADIATION
* LEVELS OF THE 1N5806.
*** CAUTION: THE MEASURED TRR AND THE PSPICE CKT. SIMULATED TRR ARE DIFFERENT
* THIS COULD POTENTIALLY LEAD TO ERRORS IN CKT. SIMULATIONS IF USED
* AS A RECTIFIER OR SWITCHING DIODE
* MEASURED TRR = 17.7NS, SIMULATED TRR = 17.2NS.
* RAD: 5E12
* TYPE: NEUTRON
* TEMP 27
.MODEL D1N5806/27C/RAD1 D (
+ IS = 3.51316E-8
+ RS = 0.120717
+ N = 1.663007
+ TT = 1.85E-8
+ CJO = 2.7476E-11
+ VJ = 0.4
+ M = 0.204799
+ EG = 1.11
+ XTI = 3
+ KF = 0
+ AF = 1
+ FC = 0.8991
+ BV = 213.5
+ IBV = 5E-6
* MEASURED TRR = 17.68NS, SIMULATED TRR = 17.97NS.
* RAD: 2E13
* TYPE: NEUTRON
* TEMP: 27
.MODEL D1N5806/27C/RAD2 D (
+ IS = 2.76017E-8
+ RS = 0.113459
+ N = 1.645347
+ TT = 1.9E-8
+ CJO = 3.25853E-11
+ VJ = 0.4359477
+ M = 0.233045
+ EG = 1.11
+ XTI = 3
+ KF = 0
+ AF = 1
+ FC = 0.5
+ BV = 1E5
+ IBV = 1E-3
* MEASURED TRR = 11.7NS, SIMULATED TRR = 11.8NS.
* RAD: 2.73E14
* TYPE: NEUTRON
* TEMP: 27
.MODEL D1N5806/27C/RAD3 D (
+ IS = 5.69489E-8
+ RS = 0.1455731
+ N = 1.709307
+ TT = 9.3E-9
+ CJO = 5.31594E-11
+ VJ = 0.4
+ M = 0.4023053
+ EG = 1.11
+ XTI = 3
+ KF = 0
+ AF = 1
+ FC = 0.8991
+ BV = 1E5
+ IBV = 1E-3
* MEASURED TRR = 13.14NS, SIMULATED TRR = 10.17NS.
* TEMP: -55
.MODEL D1N5806/-55C D (
+ IS = 5.34578E-8
+ RS = 0.0640264
+ N = 1.7823373
+ TT = 7.65E-9
+ CJO = 3.21228E-11
+ VJ = 0.3
+ M = 0.2
+ EG = 1.11
+ XTI = 3
+ KF = 0
+ AF = 1
+ FC = 0.5
+ BV = 1E5
+ IBV = 1E-10
