Jun 21, 2010 #1 S sukhdeepmankoo Member level 2 Joined May 14, 2009 Messages 47 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 1,616 hi, what will be the speed of RAM and ROM ,if LPC2378 is operating at 72 Mhz clock?
Jun 24, 2010 #2 C chanchal.chauhan Full Member level 4 Joined Apr 23, 2009 Messages 216 Helped 5 Reputation 10 Reaction score 1 Trophy points 1,298 Location Hyderabad, India Activity points 2,539 Re: speed of RAM and ROM I feel based on the clock frequency speed will change. If you are using higher clock frequency it will increase the speed of memory. To find out the speed of memory its not a guess work. If you find out then please let me know. Regards Chanchal
Jun 25, 2010 #3 S sukhdeepmankoo Member level 2 Joined May 14, 2009 Messages 47 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 1,616 Re: speed of RAM and ROM suppose i am running the ARM processor(LPC2378) at 72Mhz. i have read the datasheet that internal Flash can run at max frequency 20Mhz. but not menetioned anything about the speed of RAM. Can u tell me what is the max speed of RAM? Thanks
