The size of pmos pass transistor in LDO regulator
rogerqin
Junior Member level 1
Hi, all
I am designing a LDO regulator, the minimal power supply voltage is 4.75V, and the output voltage is 4.5V, the maximum output current is 20mA. In order to assure the pmos pass transistor operating in saturation, I have to set a large W/L, but i can not provide this area.
My question is that if I choose a smaller size, then the transistor of pmos pass transistor may operate in triode region. What performance of regulator will degrade?
When I simulate, I found that only the psr performance degrades.
Is there anyone have the experience about this problem? Thanks for your help.
transistor sizes as of 2007
Did u simulate output noise and transient loading output variation? I think both of them should be degraded as well.
If all three performances are not of your concern, you can go ahead to use it in triode region.
ldo with pmos pass gate
I have simulate the transient loading variation, it seems no problem. I have not simulate the output noise, but only power supply rejection, which is decreased about 10dB than the condition that the pmos pass transistor operating in saturation region.
If I can accept the decrease of psr, I am not sure whether there is other problems.
calculating transistor size for ldo
You may try simulate large loading current variation and your PMOS will go even deeper in triode region. Actually, what u need to consider is in real system, the transient loading can be larger than your expectation, not necessarily in your 20mA as 20mA is JUST a DC value, not peak-to-peak value. Your PSRR may create problems if your LDO used in RF system.
As your PMOS is in triode region, your output impedance can get smaller and so it would affect your PM, which can be worse
pmos pass transistor saturation ldo
when pass transistor operates in triode region the loop gain will decrease drasticly.In order to get a reasonable gain error, make sure the loop gain is larger than 60db even at worse case.
pass transistor pmos
But PSRR is the Key performance for the most application of LDO
ldo region
the pass device size is only decided by the maximum output current.
and in light load, ofcourse the pass device will be in triode. so you should keep loop gain large enough at all loads.
pmos vs nmos ldo pass transistor
PMOS size is decided by max output current .You must make the pass MOS gate voltage still keep the input diff pair and pass MOS in saturation region .
pass transistor in ldo
pmos transistor size depends on maximum load current,available vgs for the pass transistor and drop out voltage.
simulate the output impedance of ldo regulator
Is your pass transistor working all the time in triode region ? It would be a big trouble if you have it working at triode and saturation as well. As you know, the expression for the current change from square behavior to logarithmic, this might lead you to undesirable effects such as lower ripple rejection, transient response and furthermore, stability issues due to the "slewing" (not the electrical concept) you introduce when working at triode region.
