The relation between the Delay slew load arrival time and required time.
sailu
Newbie level 2
hi friends
please tell me the relation between the Delay slew load arrival time required time.
i mean in the column of the timing report, how ti get the arrival time
i have setup time violation, what i have to do to get the positive slack.(how to reduce the arrival time ? ).
please give me the detail explanation.
thanks in advance.
Re: timing report
One way to reduce arrival time is to reduce the Combinational logic between start point and end point(on the top of the report you cna find). Another way , to introduce pipeline register. With this you are splitting the combinatonal logic so you get +ve slack.
Re: timing report
you can use command "set_critical_range" and "group_path".
Usually, this will lead the tool to optimize the critical path.
David
timing report
Added after 18 minutes:
hi what is the relation between the Delay slew load arrival time , required time.
