Alanlin
Newbie
I use a small solid state DC controlled DC normally open solid state relay with 4 pins: IN+ IN- OUT+ OUT-.
The connection method of the S3C2440 selected by the main control chip is as follows:
OUT+, OUT- are used as switches to control the charge and discharge of the capacitor;
IN+ connects to 5V power supply; IN- connects to 2440 GPIO through a 470 ohm current limiting resistor;
The problem now is: as long as the circuit board power is turned on, the relay is in the closed state and is not controlled by the 2440.
Relay parameters: control voltage 3-14V Control current 6-15mA
