the proper value of Vgs-Vth of the input MOST
swolf
Newbie level 6
I am designing a folded cascode OTA for pipelined ADC. It requires 400M Hz GBW with lowest power consumption. the load capacitance is fixed (i.e. 4 pF), so i need to design the input MOST to get the largest gm under the lowest id of the input MOST.
as we know, gm is inversely propotional to (Vgs-Vth), the question is: what is the proper Vgs-Vth?
i designed the mosts and simulation result is:
#(0.18um process) the simulation tool is Spectre.#
w=300u, L=0.18u, Id=1.023mA, Vgs=558mV, Vth=470mV, Vdsat=118mV, Vds=1.187mV, gm=14.6mS, ron=1.16K
is this value (Vgs-Vth=88mV) proper? would it course some problems in reality? or can i still decrease the Vgs for more larger gm? what is the proper value in reality?
Would you give me some hints? Thank you in advance!
hr_rezaee
Advanced Member level 3
Iran-Mashhad
As I know, gm is proportional to (Vgs-Vth) directly.
As I know, in 0.18um process, Vov<100mV is not good
because MOSFET behavior in this Vov is similar to sub threshold.
regards
gpwu
Member level 2
I think your device is in triode region.
Better to design VDS > VDSAT, so that the device is in sat region.
swolf
Newbie level 6
i am sorry that i typed a wrong value: Vds should be 1.187 V
gm=2*Id/(Vgs-Vth), when Id is fixed, we can obtain larger gm by decreasing vgs-vth, is that right?
so what will happen to the circuit when input mosts operates in the sub threshold?
thank you
yschuang
Full Member level 3
gm=2*Id/(Vgs-Vth) is valid for strong inversion, which means your Vgs-Vt is larger than 2nVt. 2nVt is around 78mV and depends on what technology you use.
As I know, for low power design, input devices operate in the moderate inversion, which operate between the strong and weak inversion.
hr_rezaee
Iran-Mashhad
yes, it is true.
sorry.
DenisMark
Full Member level 6
Russia
GBW=Gm/Cload, where Gm-transconductance in input diff pair. Vgs-Vth=88mV ans Gm/Id=14.3 indicate moderate inversion level. U can increase Gm/Id up to about 20-22 in weak inversion region (Vgs-Vth<-50mV) simultaneously decrease Id (power consumption).
Also for diff pair in weak inversion u can use PTAT current reference to make GBW close to constant.
Weak and moderate inversion level is optimal region for amplifier. Strong inversion for diff pair is used in Gm-C filter where linearity in attention.
yschuang
Full Member level 3
Very clear for me. I was still wondering how you get a rough number like 14.3 or 20-22 for moderate or strong inverison by using BSIM model. I know some people like Jesper or Binkley use EKV models and they can decide what regions the devices are in.
gpwu
Member level 2
Yes, it is right.
Input pair works in weak inversion is OK.
Although most model is not very good in modeling ro in this region.
