The Kill A Watt LCD driver
evios
Junior Member level 1
kill a watt serial interface
Hi all the experts here:
Basically I was having my project. But then I need the data from a device called Kill A Watt. Before it has been drived to the output, there are 6 connections to the LCD driver as shown below:
The LCD seems to have 20 pins configuration:
Can anyone advice me for that? Because I really need it for the project. Thanks.
Any references are welcomed too.
1-wire kill a watt
Some LCD has serial interface that's why you have 6 wire ribbon cable, 20 pins it is COG(chip on glass) display, so your PCB can drive two different types of the display
lcd driver 6 wire
If it is a standard alphanumeric display you need 6 wires to use in 4 bit mode. Cannot really tell from your photos whether Alpha or Graphic.
You need
D4-D7 4 wires
E 1 Wire
RS 1 Wire
Connect WR to ground (write mode)
Power of course
And I think CON connects to ground for darkest display, really needs around 10k pot across power, with centre to CON
Not sure of connections if its a graphic display.
configure kill a watt
Thanks for the replies!!!
But what is meant by these pins anyway?
D4-D7
E 1
RS 1
Sorry I just found it a bit complicated. Thanks again.
kill a watt setup
D4-D7 are data lines Leave D0-D3 unconnected
E = Display Enable
RS = Display Reset
As you are probably only writing to the display, you should connect W/R to 0V
Apart from power and contrast, these 6 lines are all the data connections you need for 4bit operation. Always assuming that this is an Alphanumeric display, and your software is setup to operate in 4 bit mode. If this is a graphics display, the the above will not apply, there are different sorts.
lcd graphics display chip on ribbon cable
Well thanks for the reply...
I think this is more like Alphanumeric display.
I just want to get the reading out and input into PIC
This is a custom display, just for this meter. What I have said before is not relevant to this.
Sorry no idea how you would extract data from this unit. Its my guess that the display is a serial device.
