Hi all!
I have a problem with PIC18F97J60, writting code on MCC18 & MPLAB IDE v8.76. I can not communicated with COM port 1.
This is my c code:
#include "p18f97j60.h"
#include "global.h"
#include "usart.h"
void main(void)
//Delay10KTCYx(125); // = 10000*Value*Tcy = 10000*x*0.16 = 200ms
Init();
//debug on COM port 1
#ifdef _UART1_USE_
putc1USART('\n');putc1USART('\r');
putc1USART('O');
#endif
while(1)
}//end while
}//end main
void Init(void)
TRISA = INIT_TRISA;
TRISB = INIT_TRISB;
TRISC = INIT_TRISC;
TRISD = INIT_TRISD;
TRISE = INIT_TRISE;
TRISF = INIT_TRISF;
TRISG = INIT_TRISG;
TRISH = INIT_TRISH;
TRISJ = INIT_TRISJ;
PSPCONbits.PSPMODE = 0; //Disables the PSP port on the chip.
//INTCON2bits.RBPU = 0; //Internal PORTB pull-up resistor feature (1:On , 0:Off).
PORTAbits.RJPU = 1; //Internal PORTJ pull-up resistor feature (1:On , 0:Off).
LATAbits.RDPU = 1; //Internal PORTD pull-up resistor feature (1:On , 0:Off).
//LATAbits.REPU = 1; //Internal PORTE pull-up resistor feature (1:On , 0:Off).
configureUSART(9600);
void configureUSART(unsigned int baudrate)
unsigned int spbrg;
TRISCbits.TRISC6 = 0; // set TX (RC6) as output
TRISCbits.TRISC7 = 1; // and RX (RC7) as input
TXSTA1 = 0; // Reset USART registers to POR state
RCSTA1 = 0;
TXSTA1bits.TXEN = 1; // Enable transmitter
RCSTA1bits.SPEN = 1; // Enable receiver
//spbrg = (CPU_CLOCK/16)/baud - 1 , (High Speed)
//spbrg = (CPU_CLOCK/64)/baud - 1 , (Low Speed)
switch(baudrate)
case 2400: spbrg = 650;
break;
case 4800: spbrg = 324;
break;
case 19200: spbrg = 80;
break;
case 38400: spbrg = 39;
break;
case 57600: spbrg = 26;
break;
case 115200: spbrg = 12;
break;
case 500000: spbrg = 2;
break;
case 1000000: spbrg = 0;
break;
default: // 9600 baud
spbrg = 161;//40;
break;
//Asynchronous mode, high speed(BRGH=1): (FOSC/(16 x Baud rate)) - 1
//Asynchronous mode, low speed(BRGH=0): (FOSC/(64 x Baud rate)) - 1
//Synchronous mode: FOSC / (4 * (spbrg + 1))
baud1USART(BAUD_8_BIT_RATE & BAUD_AUTO_OFF);
// Open1USART( USART_TX_INT_OFF & USART_RX_INT_OFF & USART_ASYNCH_MODE & USART_EIGHT_BIT & USART_CONT_RX & USART_BRGH_HIGH, spbrg );
Open1USART(
USART_TX_INT_OFF &
USART_RX_INT_ON & //recieve interrupt on
USART_ASYNCH_MODE &
USART_EIGHT_BIT &
//USART_CONT_RX &
USART_BRGH_HIGH &
USART_ADDEN_OFF,
spbrg );
//Interrupt on Transmission:
//USART_TX_INT_ON Transmit interrupt ON
//USART_TX_INT_OFF Transmit interrupt OFF
//Interrupt on Receipt:
//USART_RX_INT_ON Receive interrupt ON
//USART_RX_INT_OFF Receive interrupt OFF
//USART Mode:
//USART_ASYNCH_MODE Asynchronous Mode
//USART_SYNCH_MODE Synchronous Mode
//Transmission Width:
//USART_EIGHT_BIT 8-bit transmit/receive
//USART_NINE_BIT 9-bit transmit/receive
//Slave/Master Select*:
//USART_SYNC_SLAVE Synchronous Slave mode
//USART_SYNC_MASTER Synchronous Master mode
//Reception mode:
//USART_SINGLE_RX Single reception
//USART_CONT_RX Continuous reception
//Baud rate:
//USART_BRGH_HIGH High baud rate
//USART_BRGH_LOW Low baud rate
Can anybody help me?
Thanks a lot very much !!
