Register Log in
The explanation of offset voltage concept
suraj
Junior Member level 1
Regarding Offset Volatge
Hello Friends,
If you we reduce the (VGS- VTH), then input offset referred offset voltage decreases but at the same time current mismatch increases. Can you please explain me this concept.
Suraj
sunking
Advanced Member level 3
Re: Regarding Offset Volatge
please give more information,such as pic.
suraj
Sir I don't have pictures.
This is related to the Differential amplifer given in Dr. Raazvi's book P 468- 470. In which input refeered offset volatge decreases with the decrease in (VGS- VTH), but current mismatch increases.
Suraj
sutapanaki
US
There are two view points for the gm of matched transistors and how it affects offset and current matching.
gm increases as you reduce Vgs-Vt i.e the overdrive voltage.
If you have an offset in a diff amplifier, you'd want to apply a compensating differential voltage at the input in order do remove the offset. This is in fact the input referred offset of the amplifier. The smaller it is, the better. That means that we want to have an amplifier that is quite sensitive, so a small input voltage is enough to compensate for a given offset at the output. In general vout=gm*ro*vin.
ro is not very much under our control, but gm is. Increasing gm makes the amplifier more sensitive and hence a smaller input referred offset results. And this means we need the diff. pair transistors to have small overdrive voltage.
In matching currents in a current mirror we want exactly the oposite thing - if two transistors who are supposed to be perfectly matched are in fact not, then this will result in mismatch in the output current of the mirror. That is, if there is a threshold voltage difference between the two transistors, the current error will be of the order of gm*(deltaVth) and of course we need to reduce gm to have small error i.e. we want a mirror that is not very sensitive as oposed to what we wanted for differential amplifiers. As a result, the overdrive voltage of the mirror transistors needs to be big.
Edward_2288
Member level 4
Hi..
it is obvious from the equation derived by the author. it can be seen that the offset is inversely proportional to the gate overdrive voltage of the differential pairs.
Toggle Sidebar
Design Fast
