The differences between various I2C buses
sujithchakra
Junior Member level 1
Could any one please explain the differences between....
1) I2C bus core
2) I2C bus controller core
3) I2C master core
4) I2C slave core
Thanks,
Sujith Chakra
windowX
Re: I2C bus
Hi,sujith,I think you should give more information about these cores.
in the literal meaning, I guess:
1) and 2) can refer the same thing, they may either be a I2C master core
or a slave core, or even a core with master controller and slave controller.
3) refers to a core that only implement I2C master protocal, and can only
been used as an I2C master controller.
4) refers to a core that only implement I2C slave protocal, and can only
been used as an I2C slave controller.
Any way, I am not very sure about my answer.
Hands.
windowX.
akshay.raoy
Junior Member level 2
Re: I2C bus
sss i think thts correct.....
use this for i2c pdf....
alam.tauqueer
Full Member level 2
I2C bus
The above answer is absolutly right,for more detail go through the spec.
