The difference between SPI and the I2C busses on a PIC.
BD
Member level 1
Micrcontrollers
I want to know the difference between SPI and the I2C busses on a PIC.
Which would be better for Bit Bashing?
Thanks.
ntfreak
Full Member level 3
UK
Re: Micrcontrollers
If you require master only then both are easy to implement in software, slave mode requires a lot more work and most people would settle for a device with a onboard peripheral.
Speed wise spi will run faster than I2C, most serial eeproms run @ 60MHz these days, not that a pic woul get anywhere near that.
Regards
NTFreak
