I/O buffers: To latch the data from the pheripheral devices.This buffer is specifically used because it is not possible for the pheripheral device to send the data to the processor when the processor requires it(because clock synchronization is not possible).So these I/O buffers latch the data from the I/O devices and sends the data to the processor with synchronisation.
Clock buffers: In a microprocessor, since a single clock drives the entire processor, the signal may become weak and may not supply the clock signal to every part of the processor.So clock buffers are used to boost up the clock signal
Data or Ordinary buffers: These are primarily used to produce intentional delay in the data paths.In asynchronous circuits are used to prevent races..
